Message 11 of 13
Re: Full Fibre Pre-installation Issues.
That’s precise information and it answers my question perfectly regarding the Ethernet cable run. I can now check where the spare conduits run from the garage to the attic and then down into the office. I’ll pre‑install the cable through those routes and leave plenty of excess at both ends so the engineer has flexibility during the router installation.
Thanks again.
Message 12 of 13
Excellent. In other words, use the redundant internal disconnected copper telephone cable to connect the phones from the router?
Message 13 of 13
See this Digital Voice FAQ compiled by forum member @licquorice
Solved: Digital Voice FAQs - BT Community
