Message 1 of 5
Full fibre no better
I've had full fibre to the door now for over a year and i find little or no difference to my old broadband.  You tube and other videos are still buffereing.  I tried restart the router and the fibre box so many times and resetting.  Fed up.
Any help or suggestions would be most appreciated
I have a macbook air 2018
Thank you
4 REPLIES 4
Message 2 of 5
Re: Full fibre no better
What router are you using
Message 3 of 5
Can you run. Fast.com.  and post results. Must be with ethernet connection
Message 4 of 5
You will need to add an ethernet adapter via thunderbolt to take advantage of full fibre
Message 5 of 5
Hi @Leon1225 and welcome to our community.
How are you testing the connection speed? Wired or wireless? If wireless have you tried changing wireless settings etc? Give us as much detail as possible and we'll try to help.
Cheers
David
