Message 1 of 2
Hybrid connect
Just received the hybrid connect kit. I can only get ONE blue bar, wherever I move it. Is this OK?
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: Hybrid connect
Not great according to the help file, the suggestion is that 2 - 3 bars is good.
Use the Cellmapper website to identify where your best EE mast is located. You might even need an external 4G aerial to get a decent signal, but BT don't supply them.
Otherwise it recommends calling BT on 0800 800 150 if you are struggling to get a good 4G signal.
