Message 1 of 13
Is FTTC being upgraded?
Afternoon all,
So our estate is FTTC with pretty average superfast speeds (circa 39Mb).
The last couple of days a BT/ Openreach contractor (FNC) were lifting the covers up and down the street to the ducts on the path installing fibre optic cables. I did ask him if we were finally getting Ultrafast broadband, to which he replied its fibre optic cables.
Is it safe to assume they’re laying the ground work for the estate to be upgraded to FTTP? If so, how long (roughly) does the big switch on take?
Thanks in advance,
Sam
Tags (2)
12 REPLIES 12
Message 2 of 13
Re: Is FTTC being upgraded?
How long is a piece of string. It can take months or years for  FTTP to be available. Only Openreach will know the schedule and they will not share that with you.
Message 3 of 13
Message 4 of 13
Its in scope, i’d checked that before, timeframe of 2021-2026.
Was just asking/ checking if anyone knew whether the fibre work conducted outside our house is a prelude to the major work on the cabinet starting?
Message 5 of 13
As per my previous post. Once the infrastructure ie the fibre is laid it can still take a long time for FTTP to be available and until it is Openreach will not give you a date.
Edit: For info FTTP does not use the cabinets.
https://www.bt.com/broadband/full-fibre-learn
Message 6 of 13
No problem, thanks for the reply
Message 7 of 13
As an update, my postcode/ address is now eligible for FTTP… it seems their cable installation a few weeks ago is now live and active
I have an order waiting for completion… very happy
Message 8 of 13
Thanks for the update @samharman88 .
Appreciate you taking time to let us know.
Cheers
David
Message 9 of 13
Lucky you. At our place we've had all the fibre installed in the ground and I've seen CBTs at the top of the poles and, in a duct outside our house, in the ground. FTTP is now available .... but not with BT. It is being offered by two (!) minnow companies which I can imagine will fold once they have burnt through their government grants. You are one of the lucky ones!
Message 10 of 13
Are the minnow companies using the OR infrastructure?
That would be very interesting!
