Message 1 of 27
KCI2 Assure
FTTP is finally available for my house. But on the wholesale checker it says KCI2 Assure under FTTP.
Looking on different topics I believe this only happens when an install is ongoing. Is this correct?
But I have not signed up to any providor yet.
26 REPLIES 26
Message 2 of 27
Re: KCI2 Assure
KCI2 assure is a two stage install ( it’s not what you think ) basically at the network survey stage before the FTTP network was built , an issue with your address ( although the same issue may affect many others ) was identified that requires the installation to be done in two stages , this only happens if an order is raised , if no order comes in no work is done ( apart from the work already done to get FTTP into the area , that work was what enabled orders to be raised via ISP’s in the first place )
 An example could be , someone’s existing copper pair service is underground but not ducted, the fibre network is available but 20m away ….the first stage is to get a duct from the FTTP location 20m away to the  house wall , requiring excavation in the footpath and an agreed route through the  garden , once this is agreed and the first stage work is done , there is the means to get a new optical cable to the  house wall from the location of the FTTP equipment , the second stage ( obviously dependent on success of the first stage ) completes the installation ( the work to fit the FTTP equipment in the home ) ….this isn’t the only reason KCI2 is stated , but gives an idea why some installations can’t be done in one visit , even someone with an overhead service ( so an existing copper cable from a telegraph pole )  , could be KCI2 , if installation of a new overhead optical cable would present issues .
The checker you used to establish your address is KCI2 also gives an indication of what the  issue is , it looks like this ( although this is not a KCI2 , but a straightforward installation address )
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential UG Feed with no anticipated issues.
Message 3 of 27
Re: KCI2 Assure
Thank you for your detailed reply.
These is the status when using the BT checker. I do have underground cabling but I was told by open reach who were working on my round a few weeks ago it is in a duct.
Message 4 of 27
Re: KCI2 Assure
@Iceman1
The note states "Single Dwelling Unit Residential UG Pre built to curtilage Soft"
This usually means they have ducted and put a Toby box near your property boundary. The curtilage Soft then means a dig maybe required to install duct from that Toby box to the property outside wall but as it's soft I'm assuming it maybe garden like grass or soft material that can be dug up and then put back down and made to original state.
This will be why it's also a "2" stage install (aka KCI2) rather than a 1 stage install
Message 5 of 27
Re: KCI2 Assure
Thanks for the reply.
There is a box on the pavement which is about 30m away. The first 25m of this is tarmac and the last 5m to my house is grass.
So I assume the last bit is the soft area it's referring to.
Message 6 of 27
Re: KCI2 Assure
If your property had a duct then there wouldn’t be the need for a new toby box in the footpath opposite your property….., no duct was the default situation for property built in the 1960’s till the early 1990’s.
What does the 30m refer to ? , is your front garden 30m in length and 25m of that is tarmac ? or have you have seen a toby box 30 meters away , and from there it’s 25m in the public footpath and 5m across your garden ( your garden being around 5m long ) ? , if the second option, are you sure there  isn’t there a closer Toby  box than the one you have seen  ? , if there isn’t , then it’s not really built to your  curtilage ( the boundary between your property and the public footpath )  , the correct survey note should be ‘partial DIG’ .
As stated , built to the curtilage soft should mean that at the boundary of the public footpath and your garden opposite your house there should be a new Toby box and from there to your house wall it’s should be mainly soft surface, ( that’s to  the proposed location where the new excavation would meet the house wall ) it’s not necessarily where the existing copper line enters , if the route  to the most convenient point  on the house wall had mainly to cross  hard surfaces like concrete, tarmac, brick pavers etc , then the correct survey note is build to the curtilage hard .
When the civils teams install toby boxes they try to avoid being opposite driveways and hard landscaping and opposite lawn ( soft ) surfaces , but obviously if someone had nothing but hard surfaces outside their property then it’s impossible to avoid them , footpaths can also be pretty congested places with other buried services , so the ‘best’ location for the Toby box  may not be available as other buried services are blocking that location.
This  method of service  of providing a toby boxes outside each property , or one outside a pair of semi’s is the same as what the cable industry did 30 years ago .
TBH, from your point of view , provided you agree to the excavation route , then it’s not really of any consequence to you if it’s soft or hard surfaces , a survey network note ( SNN )  is a guide for Openreach , this would only affect you if the excavation required was so great that the excess costs involved would require you to make a contribution towards them .
So in your case , it’s two stage installation, and the first stage consists of a visit to explain what’s required and the proposed route and if you are happy to proceed ( there will be situations where a scar down a newly landscaped garden/driveway means the householder changes their mind after being told what’s necessary ) but assuming you consent to what’s needed , an excavation and duct are installed from the nearest toby box to your house wall ….the first stage techs may also install the optical cable through the duct to the house wall once they have the  duct installed , or may leave the duct roped so the cable can easily be installed by the second stage engineer …either way , once the first stage is ‘booked off ‘ , the second stage appointment can be arranged ( this is the contractual date ) and the external cable is provided and spliced at a newly provided CSP block on the external wall to  an internal optical cable which is  ran to the location of the ONT inside the house , and the service authenticated, router connected etc .
Message 7 of 27
Underground ducting direct to property?
My existing phone line comes to my house via underground ducting.
My question is, does and should the ducting run right up to my house wall where the cable comes out?
I ask as when I got a driveway done a few years ago, the cable 'popped' out from the ground about 2m away from the box that is on my wall. There was definitely no ducting for this last 2m.
This open reach photo I've found also suggests the ducting is not straight to properties, is this correct?
If that is the case, I'm just concerned on how they will install a new fibre cable to my house if the duct is directly all the way to my house.
Message 8 of 27
Re: Underground ducting direct to property?
The image you have posted is for a road crossing , before ducts are connected to and from it , so the duct type , depth of cover etc are irrelevant and it’s not helpful in regards to the duct to your house wall …
however the duct to your house should be all the way to the house wall not 2m short , about this distance the duct should join with a duct 90 degree bend that allows the duct to emerge at the house wall , however although the duct is Openreach property ( or BT before Openreach ) , the developer/builder of the house does the groundwork supposedly to BT/OR specifications , unfortunately they don’t always to the correct thing , so if your duct stops short , it’s possible the developer had no 90’ bends , didn’t reinstate the ground until a cable was inside the duct , then backfilled, and said it was done correctly ( what the eye can’t see etc ) ……so getting a new cable into that duct and up-to the house wall may be problematic, and should you order FTTP it’s entirely possible you will have to agree to excavation to repair or replace this defect
If this is under a newly laid drive ( or even an old driveway you don’t want interfering with ) and you don’t consent to excavation, the order is cancelled , it’s better to be aware of this before an order is made , what is never considered is a request from the home owner for the entire driveway to be replaced to avoid a ‘scar’ in the surface ….some surfaces , like block pavers aren’t really a problem as they can be taken up and put back down with no ‘witness marks’  , but concrete or resin bonded surfaces will have a scar where the work took place , so if you don’t want that it’s probably wasting everyone’s time ordering .
Message 9 of 27
Thanks for the reply. And yes it is block paving so hopefully not too painful removing it.
Also I'm hoping they can access most of the duct and therefore only dig a small amount find it.
Message 10 of 27
Generally the push a rod down the duct from a joint box until it hits the stoppage , they know the length of the duct that went in , make an educated guess at the path/route the duct takes underground, so know where roughly the stoppage is , then excavate around that area to expose the stoppage, in your case a spilt duct bend ( so the copper cable doesn’t need cutting ) joins the now exposed duct end and completes the duct to the house wall , this is probably what should have been done years ago at the time of construction.
