Message 1 of 4
No Internet
I haven't had Internet all day. I've tried the usual turning on/off. I've checked the wires are in and secured. I've tried the check button on mybt but you need the Internet to use it.
3 REPLIES 3
Message 2 of 4
Re: No Internet
And have you reported the fault?
Message 4 of 4
Re: No Internet
I've tried but for some reason I couldn't connect with the message us page so I'm going to try ringing tomorrow. I do know that the fault is on their side as when I tried to connect to the hub it came up with a message saying that.
