Message 21 of 27
Re: Returning to BT from Sky - why are my connection speeds now limited?
As can be seen from your router statistics your max attainable rate is around 76Mb  , so on an 80Mb profile and without any ‘faults’ on the line , allowing for overheads etc , around 70Mb should be achievable, as stated already , it’s pretty clear your line has been provided as Fibre 1 ( 55Mb ) irrespective of what the BT guides are saying ( that you are already on F2 and the speed is what it is ) ….there have been occasions on here where the BT Mod has intervened and got the correct profile applied, if the Mod  offers to take a look , accept the offer
Message 22 of 27
@Keith_Beddoe as already stated, the line has clearly been misprovisioned as fibre1 rather than fibre2 as can be clearly seen from the noise margins.
@Haggini I will flag this to the mods, they will post on the thread requesting your details via pm
Message 23 of 27
Thank you for all your replies and advice, really appreciated.
Message 24 of 27
Its odd that Sky have now downgraded the estimate.
Message 25 of 27
Irrelevant, look at the router stats.
Message 26 of 27
Hi @Haggini
Thank you for your post and welcome back!
I am so sorry for the problems with your broadband speed.  It's clear from what you've posted that although your package shows Fibre 2 - you've actually been provisioned on Fibre 1 speeds.  It's an easy fix though so I've sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Thanks,
Robbie
Message 27 of 27
Thanks everyone for your help - here are my stats from this morning after mod intervention. Far more healthy.
