Message 11 of 16
Re: Second Line / Dedicated Connection not possible due to full fibre already being present
You can't actually order an ONT, you have to order a new service which will entail either a replacement multi port ONT or second single port ONT being fitted.
Message 12 of 16
@licquoriceYou've raised an interesting point. Where would the fibre come from for the second ONT? It can't be a splice at the CSP.
Message 13 of 16
From what I’ve read, it doesn’t need a second fibre, each fibre can carry two services so just needs to be presented correctly to the ONT I believe …
Message 14 of 16
A completely separate fibre from the CBT with its own CSP. However, there is no need for a second ONT as a multi port ONT can support multiple services.
Message 15 of 16
Correct, but the service needs to be ordered which will trigger an ONT change, you can't simply order an ONT.
Message 16 of 16
Thanks.
The challenge is to find an ISP incl BT that knows how to order a second service and trigger a multiport ONT order… Zen don’t know how and BT didn’t before but maybe now there is a live service it will be easier …
