Message 1 of 7
Slow upload speeds
Just like other posts iv seen here my upload speed is below 1mbs and I have no idea what's causing the problem. I'v also seen the mod team here have been able to help quite fast so i'm hoping i can be helped also 😅. If there is any technical information i need to post please let me know, thank you.
6 REPLIES 6
Message 2 of 7
Re: Slow upload speeds
Hi @Secretary, welcome to the forum and sorry you're getting a slow upload.
Are you using the BT Smart Hub?
If so please would you post your Hub Stats. Open a new web browser on your connected device and type 192.168.1.254 or bthomehub.home into the address bar. This will open the Hub Manager.  Click ‘Advanced Settings’ and then ‘Technical log’
Cheers
John
Message 3 of 7
Hi thank you for the reply, I am using the smart hub 2 and here is the information you asked for.
Product code:Hub
Serial number:+091298+2014019963
Firmware version:v0.38.00.10147-BT
Firmware updated:Tue Feb 21 16:01:05 2023
Board version:R01
GUI version:1.77 20_05_2022
DSL uptime:5 days,22 Hours43 Mins47 Secs
Data rate:20 Mbps / 79.999 Mbps
Maximum data rate:34.544 Mbps / 97.838 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:15.1 / 10.0
Line attenuation:5.9 / 6.9
Signal attenuation:5.8 / 7.4
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:8.4 GB Uploaded / 214.2 GB Downloaded
Broadband username:[email protected]
Public Wi-fi status:Not active
2.4 GHz wireless network name:BT-GCAFMW
2.4 GHz wireless channel:Smart (Channel 6)
5 GHz wireless network name:BT-GCAFMW
5 GHz wireless channel:Smart (Channel 36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:CC:D4:2E:A2:D2:4B
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 4 of 7
can you run btspeedtester and post results  must be done with ethernet connection
http://www.speedtestalbansb.btwholesale.com/
you can also try    fast.com
Message 5 of 7
I used fast.com and I got (on ethernet)
72 Mbps Download
400 Kbps Upload
Message 6 of 7
Hi @Secretary and welcome back.
It's beeen a while but good to see you again. I'll be happy to take a look at this for you. I'll need to run a few tests so please check your inbox for my message and drop me over a reply.
Cheers
David
Message 7 of 7
Hi @Secretary
Thanks for sending us your details.
Glad you've been able to resolve this issue with your upload.
I've closed this case but should you experience any issues again please post back.
Stuart
