Message 1 of 6
Superhub orange light
Just wondering if anyone else has had this issue. I'm currently waiting on being able to use my fibre broadband. It was installed yesterday by an engineer and I wsiyuntil midnight as advised and it didn't start working. I've been told it's an external fault and have to wait for it to be fixed and I don't need an engineer out apparently. The light on my hub has been completely orange since my installation I can see the WiFi signal but can't connect to internet. Has anyone else ever had the same issue and how long did it take to be fixed?
5 REPLIES 5
Message 2 of 6
Re: Superhub orange light
It means you have physical connectivity but your account hasn't been activated.
How long it takes to be fixed is unknown, every case is different.
Message 3 of 6
Not great though, I was told it was a fault. I was told I would be activated on my connection date so it's completely confusing. The engineer who installed it also was confused
Message 4 of 6
Call the FTTP team and see if they can help 0800 587 4787
Message 5 of 6
Are they different from the normal customer service team?   I have been on the phone twice already today about it and was told it was a fault and I have to wait.
Message 6 of 6
Yes they are different and as name suggests better equipped to deal with FTTP problems
