Message 1 of 11
Why does my account show an active order
Hi
When i click on track an oder it says an engineer is due to visit my property today. I have had full fibre installed in August so it should be complete
10 REPLIES 10
Message 2 of 11
Re: Why does my account show an active order
Hi @Patel236 welcome back to the community, we'll take a look at that for you. I'll send you a private message in a few moments.
Neil
Message 3 of 11
Hi Neil
any updates on this. I can’t seem to send you a private message.
regards.
Message 4 of 11
Hi @Patel236,
@NeilO is back in the office tomorrow afternoon. I will let him know that you were in touch.
However, his last message that I can see, says that we expect to have an update on the 12th.
I'll make sure we fix the issue with your PMs too as you should be able to reply. That may take a day or two.
Thank you
DanielS
Message 5 of 11
@DanielS
This was raised on 11th October 2023. Just out of interest, is this the same issue?
Message 6 of 11
Thank you Daniel.
yes it is the same issue Keith.
regards.
Message 7 of 11
@Patel236
Thanks, it just seemed a long time, which made me wonder about the date.
I will leave it at that. I am sure it will be sorted eventually.
Message 8 of 11
Hi @Patel236 There was a system update on Friday which should have fixed the problem you were experiencing with the order tracking in BT.com. Can you check and post back to let me know if it's still telling you an engineer is due to visit?
Neil
Message 9 of 11
All sorted now. Thanks.
Message 10 of 11
@Patel236 Brilliant, I'm sorry it took so long to fix.
Neil
