Message 1 of 4
PAC Code
Looking to see if someone can help me with a strange situation
I am moving out of BT to another provider. I was given PAC code by BT and I gave this code to the prospective provider.  I have not activated this new number yet.
I found a better deal and I want to use the same PAC to port the number.  The system is not allowing perhaps because I used the PAC once . I have requested for a new PAC code and it is taking a lot of time with BT for some reason.
Is there a better solution to deal with this matter?
3 REPLIES 3
Message 2 of 4
Re: PAC Code
have you phoned CS 03301234150 for assistance  when did/does the existing PAC code expire
Message 3 of 4
Re: PAC Code
PAC code expiring by end of this month.
I spoke with them and the answer i get is that this is specifically being dealt with another department and SLA is 4 days. It has already been 5 days now.
Message 4 of 4
Re: PAC Code
I think you have to wait until PAC code expires before you can request a new code
