Message 1 of 7
Re: Unable to change parental control settings on one of my family SIMs.
Hi,
i have exactly the same issue , I would really appreciate the same assistance please. Thanks
6 REPLIES 6
Message 2 of 7
Hi @bluebeard101 and thanks for posting.
Sorry you're also having this problem. Do you see any error messages etc? Which one of the family sims is having the problem?
Cheers
David
Message 3 of 7
I'm still waiting for a resolution. The sim in question has been like that since July.
Message 4 of 7
Hi @robin69 and thanks for posting.
We have your details in our queue. We're really busy at present but we will get to you soon. Sorry for the delay.
Cheers
David
Message 5 of 7
For the last 4 days when I go to “change settings” for the one sim, there is a yellow box with :
“We're just updating your account
If you want to make any changes, please wait 30 minutes and try again.”
My options to adjust settings are greyed out. This is only happening for 1 out of 4 sims.
Tags (1)
Message 6 of 7
@DavidM  Hi I still have this issue, what should I do?
Message 7 of 7
Hi @bluebeard101 ,
Thanks for posting. Sorry you're still having problems. I've dropped you a private message so send over the details and I'll look into this for you.
Cheers
David
