Message 1 of 58
BT is blocking my website
BT is blocking my website which is an important part of my work, I cannot showcase my upcoming events if BT are blocking my site.
https://rootedarts.org.uk
I've gone through support with the company hosting my site and they said the connection is being terminated by BT.
I have a few friends on BT who have also confirmed they cannot access the site ( it can be accessed when using an ISP hat isn't BT or EE). I have contacted the helpline who just asked me to restart my modem and have emailed BT through their various addresses dedicated to sorting these issues such as [email protected] but I have had no response.
I've put the site the urlvoid and ssltrust and they are coming back with no issues.
Has anyone else had this issue before and know the quickest way to get help?
Any help would be greatly appreciated.
57 REPLIES 57
Message 2 of 58
Re: BT is blocking my website
Also this is what I get when I run and nslookup from my home (EE) internet
C:\WINDOWS>nslookup rootedarts.org.uk
Server: UnKnown
Address: *******[hidden]
*** UnKnown can't find rootedarts.org.uk: Non-existent domain
C:\WINDOWS>ping rootedarts.org.uk
Ping request could not find host rootedarts.org.uk. Please check the name and try again.
This is what I get when I run nslookup from another provider
Server: ***********[hidden]
Address: ********[hidden]
Non-authoritative answer:
Address: 77.72.1.54
Pinging rootedarts.org.uk [77.72.1.54] with 32 bytes of data:
Reply from 77.72.1.54: bytes=32 time=11ms TTL=52
Reply from 77.72.1.54: bytes=32 time=12ms TTL=52
Message 3 of 58
Reminds me of this post....BT DNS Problems - BT Community
Is it a block or just lack of BT DNS updating? Assume its not a new site.
The fix hasnt been confirmed yet but they migrated the domain to CloudFlare in the end, someone also posted over there another BT DNS post which did get resolved.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 4 of 58
Hi naylor, thanks for the response.
Site went live in August, perhaps could be a DNS update issue but would also hope that it would have  been added between then and now. Was that someone in the CloudFlare forum? I'll go take a look and possibly make a post.
Ideally just needs escalating to someone from BT with the power to help.
Message 5 of 58
No, they just updated though, in fact not even sure if it was the Cloudflare migrating that solved it in the end.
Message 6 of 58
Have just been informed by my partner that this hasn't always been an issue and only started occurring around 10 days ago so wonder if it's been mistakenly added to a blacklist.
Message 7 of 58
Might want to check out this thread see if it helps:
Help! BT blocking a website i was building! - Page 5 - BT Community
Message 8 of 58
Thanks does look similar hopefully will get a call back from safer browsing then or perhaps the heroic @Steve_M could have a similar look haha
Message 9 of 58
I'll take a look 🙂
Message 10 of 58
@rkeveratt it looks like your site has been tagged as malicious - we're checkin on why.
Are all your wordpress versions and plugins up to date? Any that you don't recognise?
Steve
