Message 1 of 8
BT Rewards Virtual Card
Hello,
I have claimed my BT virtual reward card and was told I will receive it via email soon after however it's been over 2 weeks and nothing, the only reason i switched was because I was told the service was better.. and also the reward card was a big incentive!
Is there anyone who can look into this for me as I'm getting worried it hasn't been processed.
7 REPLIES 7
Message 2 of 8
Re: BT Rewards Virtual Card
@DamienH
What date was your service activated?
It would normally be sent 14 days after that date.
Message 3 of 8
Hi,
Around 2 weeks ago I think, I work allot so I don't know the exact date, but around 2 weeks now.
Contacted the company that do the cards for BT and they have nothing on their system to say I'm getting one.
Thanks.
Message 4 of 8
A moderator should be able to help with this.
Message 5 of 8
Thanks, Hopefully they can get it sorted for me 🙂
Message 6 of 8
Hi @DamienH welcome to the community and thanks for posting. There's a 14-day cooling-off period that starts when your service is connected, once that has passed the reward card is automatically emailed to you.
I'll send you a private message in a moment so you can send over your details to the moderation team and we'll be happy to check this.
Neil
Message 7 of 8
Hello,
I have responded to your PM.
Thanks,
Damien.
Message 8 of 8
Hi @DamienH, thanks for speaking with me earlier. Just to confirm your order completed on the 7th so your reward should be sent to you on the 22nd.
Cheers
John
