Message 1 of 2
Bt essential
Hi can someone help me at the moment i am on fibre braodband and get anything between 34mbps and 36mbps but last week got 44mbps - if i switch to bt essential as im on benefits will they slow down my line and could i still get 44mbps as they are estimating on essential i will get 30-36mbps - my main question like i said is will they touch my line or will it stay as it is and just the billing adjusted ?
1 REPLY 1
Message 2 of 2
Re: Bt essential
if you qualify for BT Essential then should be a simple switch.  you will get as good a speed as your line can handle
https://www.bt.com/exp/broadband/home-essentials?s_cid=con_bt_dg-home_awin_aff_vidAJM_110483-Editori...
