Message 1 of 9
Can't creat BTID
My broadband installed 16 April 2024, and I’ve tried to create a BT ID but it says we are having issues try again later for every time. I found that someone also had the same problem before and finally solved, Please help. Thanks.
8 REPLIES 8
Message 2 of 9
Re: Can't creat BTID
Yes Im having the same problem. My account is only 14 hours old and already im regretting the descision to join BT, This is a VERY bad start for new customers.
Message 3 of 9
Hi @TERU & @llinx,
Are you getting a specific error message when you're trying to set it up? Have you ever had an account with the same username in the past?
Thank you
DanielS
Message 4 of 9
Hi Daniel,
This is my first time using BT broadband and I haven't create any BT ID before.
Also the system was automatically fill-in my email address as user name.
Please advise. Thanks.
Teru
Message 5 of 9
Thank you @TERU.
Is this the link that you tried when you wanted to Create your BT ID?
DanielS
Message 6 of 9
Hi Daniel,
Yep, this one.
And for the last step to apply, it will shown having issue and try later.
Teru
Message 7 of 9
Hi @TERU have you tried using an alternative browser?
Neil
Message 8 of 9
Hi Neil,
I tried different browsers and also tried on mobile and laptop. But same result.
Teru
Message 9 of 9
Hi @TERU,
Thanks for getting back to us.
It would be best if we looked into this for you and work out what's happening.
I've sent you a private message that you can reply back to me through.
Thank you
DanielS
