Message 1 of 4
Changing Calling plan
Hello, At present, I am on a PAYGO calling plan. I wud like to change it to the 700mins calling plan but need to know if this wud mean I have to re contract my present broadband deal (which isn't up for renewal for a long while yet)???
3 REPLIES 3
Message 2 of 4
Re: Changing Calling plan
Calling plans are totally separate to broadband.
Message 3 of 4
Hi, @ljm thanks for posting, changing the calling plan won't re-contract your broadband. There is a 30day minimum term on the calling plans so you can change between them without any hassle.
You can change the calling plan yourself in MyBT
Neil
Message 4 of 4
Thanks for that Keith and Neil 😊👍
