Message 1 of 26
False promises on setting up Full Fibre
My copper contract is ending, so I agreed a new Full Fibre with BT. Open Reach have been digging up the road outside, and other neighbours have had full fibre installation, so should be no problem.However.....1) BT saying that they were dealing with OpenReach to get a date - would not commit. 2) on 20th May they cut my existing internet off, without replacement 3) they said that they could not just get it back again - would take time - 2 weeks plus (why not just reverse what they did, in error?). 4) they sent me a mini hub. this is a lot slower, and has no cable contacts, so not suitable for my Hive, and causes problems with my ADT security 5) they then stated that OpenReach needed permission from the original housebuilder  to instal Fibre The house was built mid 80s, I've been here since 1991, and there is no mortgage, and they have been digging up the road and installing. Additionally the original housebuilder no longer exists 6)they stated that the date for Fibre installation was now 20th August (sic) 2024 7) that they could not do anything to get OpenReach to look at (note : OpenReach is a wholly owned subsidiary of BT)  😎 they have made no offer of compensation for the problems.
Is this symptomatic of the way that BT is going?I will escalate (OfCom etc), unless BT can sort out and instal by the end of next week, and offers proper compensation.
In the meantime, be very very careful dealing with BT. I am likely to switch and publicise my problems. Twitter, Instagram, local press, Facebook etc etc
25 REPLIES 25
Message 2 of 26
Re: False promises on setting up Full Fibre
To your points ,
1.This is true , any provider using Openreach will be dependent on Openreach timescales.
2.This is unfortunate and shouldn’t really happen , any delay on the FTTP order should delay the cessation of the copper pair based service .
3.Restoration of service lost in this way does take time , it’s not simply a case of undoing what was done by ‘flicking a switch’ , this complexity is no small part is  the way Ofcom expects Openreach to deal with providers ( like BT ) something an vertically integrated company ( so the same company does network and customer like Virgin ) does have to contend with .
4.Not all providers would supply a temporary solution like this , so although it’s not perfect, you could be with a different provider on Openreach and not have any supplied connectivity at all .
5.This is abject nonsense , the representative that said this is making it up .
6.The only way this date will be accurate is if a road closure is required and the local authority have provided the date.
7. BT hold no more sway with Openreach than any other provider like Sky or Talk Talk , however OR are penalised for not hitting agreed dates so will not be hanging around they will be keen to get the work completed
Message 3 of 26
Hi @TimGlass I'm so sorry your upgrade to full fibre has gone so wrong. I'll send you a private message so you can get in touch with the moderation team and we'll be happy to look into your complaint.
Neil
Message 4 of 26
Thanks, re the replies :
4. I could hotspot (to an extent) from my phone (Vodafone). If any other supplier had done this they'd be moving heaven and earth to get it sorted - BT aren't
5. I said as much to the BT rep ('Brett') but was repeatedly told it was OpenReach legal department and BT couldn't question it. My daughters are both Lawyers, and both have confirmed that this would be false (one daughter deals with items like this every day, inter alia) BT have said tat they will not get back to OpenReach as it's 'not worth it'
6. A road closure would not be required - the cable is all there (the road was dug up a few months ago) The cable would be from my Pavement, about 12 inches from my garden. I am not on a through road, but in a close. No closure would be required. The date of 20th August was given by ee in a text message on Monday 20th May at 1614 hrs - they even gave a timescale ('between 1300 and 1800')
For information City Fibre also installed cable, and I have a slot outside my house ready to take the cable straight to my house.
Additionally, after the full fibre order an OR rep attended and marked on the pavement where the cable would come from. The paint used is still out there, and a photo can be supplied if needed
7. see 6 above - the date looks to have been given to OR by ee/BT. Is this an OfCom issue?
It very much appears that I am being fobbed off - whether through incompetence or deliberately it's hard to tell.
Message 5 of 26
On the August date, it's likely been set so far in the future to stop the order timing out & cancelling
Message 6 of 26
Whatit's more likely to do is to get the order cancelled and another supplier to be use, not BT
Message 7 of 26
Ahh yes use a different provider & put yourself at the back of the OR queue again with the same issues. Quite frankly I'm shocked to see you're still here given your comments in November "When the deal is up I'll be looking to move"
Message 8 of 26
what expected installation date were you given when you placed your order?  It is strange that you received a text message from EE with expected installation when order with BT.  BT and EE are separate companies in the BT Group
Message 9 of 26
'Same Issues'?
iniltous came back and explained that what BT had told me about access issues was 'abject nonsense'. Would the same issues be there? We have a box outside the house all ready to instal City Fibre, if there were a supplier we wish to go with who used that (Many suppliers round here use both, although in line with rules on this forum I won't name them)
'Looking to move'
Yes, I said that, but looking round the various deals, and bearing in mind my wife's views, we decided to give it a second chance, part of that being BT's reputation for service, allied with what we had been told by our neighbours about their experience of switching (same road, no problems). Unfortunate.
Message 10 of 26
Agree it was strange. Looking back the earlier emails were from EE as well. I assumed (wrongly it seems) that I was dealing with BT. Certainly whenever I called about this issue I got through to BT, as I did when I placed an order. Again, when BT called me they always stated that they were BT. My assumption was that as they were one ultimate ownership (effectively) they worked together.
