Message 1 of 3
How can I remove an old account from MyBT?
Hi All,
have just joined BT and somehow have 2 accounts in my account. Unfortunately the default account that shows is the "wrong" one. How do I delete it to just allow the correct one to show?
When I select the correct one and go back to my.bt.com it defaults to the wrong one.
Regards
Stephen
2 REPLIES 2
Message 2 of 3
Re: How can I remove an old account from MyBT?
try phoning CS 150 or 0800800150 from mobile and they should be able to help you
Message 3 of 3
Hi @sjaddy welcome to the forum. Did you call in and get the old account removed from your MyBT ok?
Cheers
John
