Hi, although help text says that return bags can be requested via MyBT, I can't find the link described "you can order one easily by logging into My BT and selecting 'Return equipment' under 'Return your BT kit'. "
If the link is there I will use it if someone can direct me. If it's not, can the text be corrected, and can I request a bag here please?
Solved! Go to Solution.
Hi there,
I'm also in a position where I need to order an equipment return bag but can't find the link!
Can you send me a PM with it please?
Thanks,
AH1980
@AH1980 Thanks for posting, I'll send you a private message in a moment and we'll be able get one ordered.
Neil
Thank you!
Hello, I'm having the same issue. Could I trouble you to send me a PM as well to arrange to have another box sent?
Thanks very much.
Hi @cael
Welcome and thanks for your post!
I can help arrange a returns kit. I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Thanks,
Robbie
