Message 1 of 2
Multiple Accounts on one User ID
Hi,
i am wondering how I can remove two old accounts off my User ID as it’s very complicated trying to do anything online.
Thanks in advance. 👍🏻
1 REPLY 1
Message 2 of 2
Re: Multiple Accounts on one User ID
Hi @Saint405 and welcome to our community.
Thanks for posting about your BTiD. I can get the old accounts removed for you, I'll drop you a private message so you can get in touch. Alternatively, if you're not using the BT Cloud you can set up a new BTiD using a different email address and just add the required account.
Cheers
David
