Message 1 of 7
MyBT
When trying to log on to MyBT to view my bills I enter my BT id and password but it then just loads the generic BT page
I have tried changing password with no change
I am using the edge browser
Any help?
6 REPLIES 6
Message 2 of 7
Re: MyBT
can you login using app on your phone?
try different browser?
Message 3 of 7
Re: MyBT
Thanks for your reply
I've now tried on chrome and firefox with the same result
Also is the same on my phone using the BT app
Message 4 of 7
Re: MyBT
Yes, mine goes round in circles too.
Anonymous
Not applicable
Message 5 of 7
Re: MyBT
Same here log in. Go to another page have login in again next page log in again.. Set up finger print log in next time I log in it's just same log in per page..
Message 6 of 7
Re: MyBT
I have this problem as well but when it goes to the BT page I click on view personalised offer where I have to log in again which shows the offers but I can then access MyBT using the drop down menus.
I am using a bookmark for the initial log in.
There is obviously some fault in the system which needs to be rectified.
Message 7 of 7
Re: MyBT
I have changed my bookmark to my.bt.com/s/apps/appsmybt/#/home   put https// at the start.  This only needs a single log in to work at the moment.
