Message 1 of 4
Re: Help! Xbox subscription!?!?!?
I have had the exact same email this evening! Never owned an Xbox in my life.
3 REPLIES 3
Message 2 of 4
I have also seen multiple threads with the same issue. Very concerning.
Message 3 of 4
Hi @Megan201,
Thank you for posting. Please could you follow the advice above and make sure you have set up 2-step authentication. I've sent you a PM as well with details on how you can contact the team.
Thanks,
Paddy
Message 4 of 4
I do have 2 step authentication in place. I will check the private message. Thanks.
