Message 1 of 4
Refer a friend
Hi
I have referred a friend to BT with the personal link
When they click on it, it says that the site is down for maintenance
They have tried on different occasions to no avail
Any advise would be appreciated
Margaret
3 REPLIES 3
Message 2 of 4
Re: Refer a friend
Hi @maggsmcgowan, welcome to the forum and thanks for your post.
The refer a friend programme is not available at the moment. The web page will be updated  to prevent any confusion. I am really sorry for any inconvenience this has caused.
Cheers
John
Message 3 of 4
Re: Refer a friend
Thank you John for your reply
Can this be done by phoning BT directly?
Margaret
Message 4 of 4
Re: Refer a friend
Hi @maggsmcgowan, the offer was only available via the website and can't be arranged by calling in. Keep an eye out as the offer may become available again in the future.
Cheers
John
