Message 1 of 3
Remove an old account from BTID
I have the same problem, can you message me so I can remove the old one please?
2 REPLIES 2
Message 2 of 3
Re: Remove an old account from BTID
Hi @jezreel62
Welcome and thanks for posting!  I have moved your post to start your own thread discussion as the one you had posted on has already been marked as solved.
I am sorry for the problems you're having.  We can help remove the older account from your BTID.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Thanks,
Robbie
Message 3 of 3
Hi @jezreel62
Thanks for sending us your details.
Glad I was able to get this old account removed for you.
Cheers
Stuart
