Message 1 of 4
Removing Multiple BT ID's
Can't seem to find an obvious answer to this, but I have an old ID on my account that is blocking me being able to use functions on my active account. Is there a way to remove the old account?
3 REPLIES 3
Message 2 of 4
Re: Removing Multiple BT ID's
@BalkanGhost welcome to the community, you should be able to toggle between the accounts to access the functions on your active account.
I'll send you a private message in a moment so you can send over your details to the moderation team and we'll be able to help you get the old account removed.
Neil
Message 3 of 4
Can you help me with same problem
Message 4 of 4
Hi @Matt132,
I've sent you a reply on your own thread Here
Thanks,
Paddy
