Message 11 of 19
Re: Silver Address
Hello,
I’ve just rang that number and they said it’s not a BT issue and I should contact Openreach, so will attempt to
Message 12 of 19
Re: Silver Address
Openreach will not help you need to place your order with your selected ISP.  If that is BT then phone the number I posted and place an order for broadband and that should start the ORDI with openreach
Message 13 of 19
Re: Silver Address
I am in conversation with Openreach, they have confirmed they have to update their database once they have approved the services for my address. So it is getting sorted by Openreach
Thank you for your advice throughout all
Message 14 of 19
Re: Silver Address
Hi
how did you manage to speak to openreach?
we are having simular issues and want an installtion
cheers
Message 15 of 19
Re: Silver Address
Hi
cheers
Message 16 of 19
Re: Silver Address
@teddy2025
The person you are replying to, has not been online since ‎01-03-2023.
Message 17 of 19
Re: Silver Address
we want to get a connection
online they say we cant but nexdoorcan but the cable supplying next door is on apole in our field
apparently they are gold and we are silver
i speak to providers they say cant help speak to openreach but are unable to contact them
all help gratefully recieved
cheers
Message 18 of 19
Re: Silver Address
Hi I emailed [email protected]
Message 19 of 19
Re: Silver Address
thanks
