Message 1 of 7
Xbox gamepass
Hello
My Xbox gamepass deal expired and I cancelled it, however it still says active on my Xbox account, can you stop this from appearing on my Xbox account?
cheers
Luke
6 REPLIES 6
Message 2 of 7
Re: Xbox gamepass
Hi @Lukeh7,
Thank you for posting. When did you cancel it? It should normally revert back to Microsoft around 30 days after its expires/cancelled.
Thanks,
Paddy
Message 3 of 7
Re: Xbox gamepass
Hi paddy
I cancelled back in september
cheers
luke
Message 4 of 7
Re: Xbox gamepass
Hi @Lukeh7,
Thank you for replying back so quickly. If you send me your details, I'll raise this with the Xbox Team.
I have sent you a private message with instructions on how to contact the team.  You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
Thanks,
Paddy
Message 5 of 7
Re: Xbox gamepass
Hi paddy
Ive sent a direct message
cheers
Luke
Message 6 of 7
Re: Xbox gamepass
@PaddyB
Hi Paddy
Did I send everything over correct?
Cheers 🙂
Luke
Message 7 of 7
Re: Xbox gamepass
Hi @Lukeh7 ,
Thanks for the message. We have your details but you didn't include your xbox gamer tag. Can you send that over also? We're really busy at present so its taking longer than usual to reply but we will get to you in turn.
Cheers
David
