Message 1 of 2
BT Cloud Dashboard
Can anyone give some help. My BTCloud icon is displayed as connected in the bottom right hand corner of my screen. However it isnt connected, my dashboard isnt available and it isnt syncing. Can anyone offer a solution or suggestions.
Tags (3)
1 REPLY 1
Message 2 of 2
Re: BT Cloud Dashboard
Hi @Futterwithtrees and welcome back.
Good to see you again. I'm sure we can get you some help with the Cloud problem. I've dropped you a message so check your inbox and send over the details.
Cheers
David
