Message 41 of 65
Re: BT Cloud - No longer available
I can login again now
Message 42 of 65
Yes - seems to have been a remote issue.
I tried again in exactly the same way and it logged in OK.
Message 43 of 65
I've also been able to log in again - just as I was waiting to get through on one of those chat messaging things to ask BT for help.
Message 44 of 65
I have also been able to back log-in - whatever was wrong appears to be cleared - I do hope whoever in BT managed this has properly logged the solution in case of re-occurence.
Message 45 of 65
Mine is also working now.
Thanks to those who helped.  🙂
Never test the depth of the water with both feet.
Message 46 of 65
Just tried again - Login success.
Fault fixed, I guess...
Good.
Message 47 of 65
@MalaSuerte
Me too, thanks BT for a prompt reaction and resumption of service.
Message 48 of 65
same with me , all working am , not working pm . have contacted the customer support who are ringing me back tomorrow pm . will post outcome
Message 49 of 65
Yipee
Message 50 of 65
