Message 11 of 16
Re: BT Wifi
I have the same issue. Is the website opt-in not fixed?
Message 12 of 16
Re: BT Wifi
Hi @AIEmpire and thanks for posting.
Sorry you're having problems opting in to the WiFi. Are you seeing any specific error messages? Can you post a screen shot of what you're seeing?
Cheers
David
Message 13 of 16
Re: BT Wifi
Hi,
When I check the box to opt-in, it does a loading screen, but then doesn't apply anything.
Message 14 of 16
Re: BT Wifi
Thanks for confirming that @AIEmpire .
Do you have a BTiD set up and are you using those details?
Cheers
David
Message 15 of 16
Re: BT Wifi
Hi, yes, I accessed that page in MyBT account under products section after signing in with my BT ID.
Message 16 of 16
Re: BT Wifi
I'll be happy to take a closer look at this so check your inbox for my message and drop me over the details.
Cheers
David
