Message 8 of 310
BT Cloud 22.12.33 not working ERROR UN1
BT Cloud on my Windows laptop was upgraded to version 22.12.33 on 26 October 2023 and has stopped working. When I check if anything is syncing I see a buttom which says resume syncing. When I click this nothing happens.
Can you help?
309 REPLIES 309
Message 1 of 310
BTCloud Error UN1
Have started getting ERROR UN1 when logging in to BTCloud on my PC. After a few attempts I am able to log in successfully. Any idea why I’m now getting this and how can it be rectified?
Message 2 of 310
Re: BTCloud Error UN1
I have been getting the same error for a few days. Any solution?
Message 3 of 310
Not resolved yet. I referred it to BT Customer Support yesterday. They are looking into it. No explanation yet of why it’s happening.
Message 4 of 310
Just an update from me. BT are still trying to resolve my UN1 issue. No one there so far knows what it means!! I’m now on my 4th team looking into it. I hope your issue has been resolved more successfully.
Message 5 of 310
Having the same persistent problem
Message 6 of 310
I spoke to BT’s technical team on the weekend. There are a number of people experiencing this problem but they haven’t been able to find out what is causing it yet. They took a video screenshot of my logging in script to see if it showed what the issue was. Hopefully that will help them.
Message 7 of 310
Hi
I too received this error after BTCloud asked to re login via browser presumeably after a W10 update...so I uninstalled BT Cloud app, restarted PC then down loaded and  reinstalled app (exactly same version as was previously installed). Logged into app and all now seems normal....
I lied....No it's not, BTcloud stopped again with same error when trying to re-login, seems to still be working on my other devices so maybe an issue with a specific windows update and certain machines...sorry for raising hopes!!
Message 9 of 310
Re: BT Cloud 22.12.33 not working
Hi @MCB I'm sorry about that, I saw a similar post from a customer yesterday. They deleted and reinstalled the BT cloud app on their PC and it started working again. Can you give that a go and let me know if it works?
Neil
Message 10 of 310
Thanks Neil
I will give that a try. Where do I find a clean version of the new app to download?
Mark
