Message 21 of 310
Re: BT Cloud 22.12.33 not working
Same here 😞
Message 22 of 310
I reinstalled the earlier version of BT Cloud (see earlier post). That worked. A couple of days ago it updated to the latest version, but thankfully it is still working.
Message 23 of 310
 On the first attempt with a clean browser I get the login screen then the error message screen comes up. The drop down sign in link on that screen just takes me round in circles.
Message 24 of 310
Hi @Ian113, @martinclayden, @andyholten, @steephill, and at @RTL, sorry you're having trouble with the Cloud service.
The Cloud team would like to investigate this further so I'll send you all a Private Message so you can get in touch with the Mod team about this,
Cheers
John
Message 25 of 310
I've complied with your request for account information, via a private message
I'm unsure how this will help with the specific BTCloud issue. I've been using BTCloud for several years
Martin
Message 26 of 310
@JohnC2    I updated my two Win 11 Desktops today and BT Cloud is working on all my PC's. I can also log into MY BT and BT Cloud.    No problems here.
Message 27 of 310
@RTL
That's interesting.
MyBT came back on again over the weekend. So that's good news.
I have two laptops - one runs Windows 11 Pro - and BTCloud works on it. The other runs Windows 11 Home and BTCloud fails.
Which version of Windows 11 are you running?
Martin
Message 28 of 310
Same for me - had to de-install the app and then re-install it in Windows 11.
Message 29 of 310
Hi @martinclayden and thanks for senidng over the details.
Before I can raise this with our Cloud team can you try the update mentioned by @RTL and @chris-leeds and let me know if that helps.
Cheers
David
Message 30 of 310
@DavidM
Just to be clear, you're asking me to remove version 22.12.33 and re-install version 22.12.33 (which is known to be faulty)?
Can you confirm, if I do this, that I will not lose the settings (principally the backed up folder set) I have created
Martin
