When trying to update software get the message
Installation Has Failed
There was an error while installing the application
Log is as follows, which means nothing to me.
2020-04-02 13:14:36> Program: Starting install, writing to C:\Users\raymo\AppData\Local\SquirrelTemp
2020-04-02 13:14:36> Program: About to install to: C:\Users\raymo\AppData\Local\WhatsApp
2020-04-02 13:14:36> CheckForUpdateImpl: Couldn't write out staging user ID, this user probably shouldn't get beta anything: System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Users\raymo\AppData\Local\WhatsApp\packages\.betaId'.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost)
at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost)
at System.IO.File.InternalWriteAllText(String path, String contents, Encoding encoding, Boolean checkHost)
at System.IO.File.WriteAllText(String path, String contents, Encoding encoding)
at Squirrel.UpdateManager.CheckForUpdateImpl.getOrCreateStagedUserId()
2020-04-02 13:14:36> CheckForUpdateImpl: Failed to load local releases, starting from scratch: System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Users\raymo\AppData\Local\WhatsApp\packages\RELEASES'.
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at Squirrel.Utility.LoadLocalReleases(String localReleaseFile)
at Squirrel.UpdateManager.CheckForUpdateImpl.<CheckForUpdate>d__2.MoveNext()
2020-04-02 13:14:36> CheckForUpdateImpl: Reading RELEASES file from C:\Users\raymo\AppData\Local\SquirrelTemp
2020-04-02 13:14:36> CheckForUpdateImpl: First run or local directory is corrupt, starting from scratch
2020-04-02 13:14:37> ApplyReleasesImpl: Writing files to app directory: C:\Users\raymo\AppData\Local\WhatsApp\app-0.4.2088
2020-04-02 13:14:40> LogHost: Rigging execution stub for WhatsApp_ExecutionStub.exe to C:\Users\raymo\AppData\Local\WhatsApp\WhatsApp.exe
2020-04-02 13:14:42> ApplyReleasesImpl: Squirrel Enabled Apps: [C:\Users\raymo\AppData\Local\WhatsApp\app-0.4.2088\WhatsApp.exe]
2020-04-02 13:14:56> ApplyReleasesImpl: Starting fixPinnedExecutables
2020-04-02 13:14:56> ApplyReleasesImpl: Examining Pin: CyberLink Media Suite.lnk
2020-04-02 13:14:56> ApplyReleasesImpl: Examining Pin: Excel 2016.lnk
2020-04-02 13:14:56> ApplyReleasesImpl: Examining Pin: File Explorer.lnk
2020-04-02 13:14:56> ApplyReleasesImpl: Examining Pin: Skype.lnk
2020-04-02 13:14:56> ApplyReleasesImpl: Examining Pin: Word 2016.lnk
2020-04-02 13:14:56> ApplyReleasesImpl: Fixing up tray icons
2020-04-02 13:14:56> ApplyReleasesImpl: cleanDeadVersions: for version 0.4.2088
2020-04-02 13:14:56> ApplyReleasesImpl: cleanDeadVersions: exclude folder app-0.4.2088
2020-12-01 18:35:37> Program: Starting Squirrel Updater: --install .
2020-12-01 18:35:38> Program: Starting install, writing to C:\Users\raymo\AppData\Local\SquirrelTemp
2020-12-01 18:35:38> Program: About to install to: C:\Users\raymo\AppData\Local\BTCloud
2020-12-01 18:35:38> CheckForUpdateImpl: Couldn't write out staging user ID, this user probably shouldn't get beta anything: System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Users\raymo\AppData\Local\BTCloud\packages\.betaId'.
2020-12-01 18:35:38> CheckForUpdateImpl: Failed to load local releases, starting from scratch: System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Users\raymo\AppData\Local\BTCloud\packages\RELEASES'.
2020-12-01 18:35:38> CheckForUpdateImpl: Reading RELEASES file from C:\Users\raymo\AppData\Local\SquirrelTemp
2020-12-01 18:35:38> CheckForUpdateImpl: First run or local directory is corrupt, starting from scratch
2020-12-01 18:35:38> ApplyReleasesImpl: Writing files to app directory: C:\Users\raymo\AppData\Local\BTCloud\app-20.6.1
2020-12-01 18:35:38> LogHost: Rigging execution stub for BT Cloud_ExecutionStub.exe to C:\Users\raymo\AppData\Local\BTCloud\BT Cloud.exe
2020-12-01 18:35:46> ApplyReleasesImpl: Squirrel Enabled Apps: [C:\Users\raymo\AppData\Local\BTCloud\app-20.6.1\BT Cloud.exe]
2020-12-01 18:35:56> ApplyReleasesImpl: Starting fixPinnedExecutables
2020-12-01 18:35:56> ApplyReleasesImpl: Examining Pin: CyberLink Media Suite.lnk
2020-12-01 18:35:56> ApplyReleasesImpl: Examining Pin: Excel 2016.lnk
2020-12-01 18:35:56> ApplyReleasesImpl: Examining Pin: File Explorer.lnk
2020-12-01 18:35:56> ApplyReleasesImpl: Examining Pin: Microsoft Edge.lnk
2020-12-01 18:35:56> ApplyReleasesImpl: Examining Pin: Skype.lnk
2020-12-01 18:35:56> ApplyReleasesImpl: Examining Pin: Word 2016.lnk
2020-12-01 18:35:56> ApplyReleasesImpl: Fixing up tray icons
2020-12-01 18:35:56> ApplyReleasesImpl: cleanDeadVersions: for version 20.6.1
2020-12-01 18:35:56> ApplyReleasesImpl: cleanDeadVersions: exclude folder app-20.6.1
