Message 21 of 44
Re: BT Cloud error code MBB3-04
Hi @BrianJSmith and @Chris179
Sorry you're also seeing this error message. Are you able to try an older URL like @VKB ?
Cheers
David
Message 22 of 44
Good morning David,
it would be useful if he has posted the old URL.
thanks, Chris .
Message 23 of 44
Re: Error Message MBB3-04
David
Getting code on two different browsers.
If I go in via MY BT   products I get the same.
If I google bt cloud and get to the www. btcloud.bt.download,
I get 503 service not available
Chris
Message 24 of 44
Thanks for that @Chris179
@VKB are you able to post the old URL?
Cheers
David
Message 25 of 44
@David M This was the link but I suspect that it points to my vault. Others just need to go into their history and find a similar URL https://btcloud.bt.com/web/app/d3a1a8d04dcb467899befe6ed9aa7976/vault#/
Message 26 of 44
Thanks again @VKB
Cheers
David
Message 27 of 44
Hello, I don't know if this will work for all but I too experienced this same error code so I deleted all my cookies & was able to log in straightaway. Hope this helps somebody but might not work for all?
Message 28 of 44
Hi No I haven't got an old URL though I have tried typing in the BT cloud URL direct  but this just takes me to the standard login screen and fails error MBB3-04 when I input Userid and valid password. (I have tried an invalid password just in case the error pops up regardless but it didn't, it requires a valid one)  I access BT Cloud only from the desktop version. I have also noticed the address bar returns a numeric only error number 900304 which is similar to the MBB3-04 user friendly? version.
Message 29 of 44
The clear cookies/cache trick worked once only.
Now back to no access error MBB3-4
Come on BT get a fix for your customers!
Message 30 of 44
What I have been doing, which does work.
1.  Log on
2. Get the error code
3. Click the URL which I saved
