BT Cloud has closed x
See our help page for further information.
Message 11 of 26
Re: Norton won’t download
I'm running 10.14.6 and it won't download!
Other post says they had to remove Mcafee before it would download, is this correct?
Message 12 of 26
@Geoph welcome to the community and thanks for your post. I'm sorry about that, what error message are you getting?
Neil
Message 13 of 26
I get two pop up messages, first says “Classic environment is no longer supported” select OK and get a Safari message “No available application can open it”
Message 14 of 26
Thanks, @Geoph  you might need to manually remove McAfee first before installing Norton.
Follow the steps in this guide
Neil
Message 15 of 26
Removed Mcafee no difference, same error messages as before.
Message 16 of 26
I’ve followed the Norton instructions you forwarded. Removed Mcafee and residual other files. Getting same error messages.
Message 17 of 26
Hi @Geoph I'm sorry about that, I believe that means your operating system is not up to date. Is it possible to update to a newer version?
BT Virus Protect covers Windows PC and Mac (desktops and laptops) and Android devices.
The following operating systems are compatible:
PC
  • Microsoft Windows 11
  • Microsoft Windows 10 (all versions)
  • Microsoft Windows 8/8.1 (all versions). Some protection features are not available in Windows 8 Start screen browsers
  • Microsoft Windows 7 (32-bit & 64-bit) with Service Pack 1 (SP 1) or later with SHA-2 code signing support
SafeCam is only available on Windows (excluding Windows 10 in S mode, Window running on ARM Processor).
Mac
  • Current and previous two versions of Mac OS
SafeCam features are not supported.
Android
  • Android 8.0 or later. Must have Google Play app installed
Message 18 of 26
I’m running iMac 10.14.6 the most recent issue.
Message 19 of 26
Hi @Geoph I believe that's Mojave and it needs to be on Catilina or newer for the BT Virus protect to be compatible.
Message 20 of 26
Is that correct? A lot of older IMacs won’t run the 64 bit Catalina. And if I up grade my version of Word won’t work. I can’t believe Bt would release an update that will impact so many customers.
Also as I’ve removed Mcafee I’ve no protection on my PC now!
