Message 11 of 18
Re: Parent Controls not working
Once again parent controls are not working for me. I turn it off via bt website account or via bt app - the controls remain on (despite showing as off!). I turn them back on, then off again, nothing. I turned them off and checked 8 hours later, still they were active despite showing as off.
The controls for parent controls are not fit for purpose, I’m considering changing provider because this is rediculous.
Message 12 of 18
@MrRat your case is exactly what I am currently experiencing with my BT network.
BT, please can this be sorted out soon?
Message 13 of 18
Hi @MrRat and @Gozie005
I recommend speaking with our customer care team so that this can be looked into. They'll be able to access your account to make sure that everything is showing correctly from our side.
Chris
Message 14 of 18
I did this a few months ago, it was eventually solved. Now it’s not working again. It’s annoying to have to keep contacting them to solve the same problem.
Message 15 of 18
@Christopher_G  I did contact the customer support team on the 27th of October 2024, and the customer representative advised me to reset the router which didn't fix the issue. He then told me to wait for 2 weeks before someone from the offline team could investigate it. He also mentioned that a text message would be sent to my mobile to help me avoid the queue when next I call, but unfortunately, after more than one week, I am still waiting for the text message.
This is completely ridiculous just to say the least. Please guys I need this sorted, or someone take ownership of this issue.
Message 16 of 18
Hi @Gozie005
I am really sorry we have no account access on the community to get this looked into for you.
If you could get back in touch, the team will check the account history to see what has been completed and provide an update.
Leanne.
Message 17 of 18
Strangely this has now started working. I hope it stays this way.
Thanks guys.
Message 18 of 18
Thanks for coming back and letting us know @Gozie005.
Katie
