Message 1 of 2
parental controls not working
Hi,
I am struggling with the set up and it seems from other posts i need BT assistance. i have young children in the house and am worried about the free access currently available.
1 REPLY 1
Message 2 of 2
Re: parental controls not working
Hi @jonathan19, sorry you're having trouble using the Parental Controls.
Firstly check that you are using BT's DNS settings: How to check your DNS settings | BT Help
There is also this section on the website which may be helpful: BT Parental Controls - Keep Your Family Safe Online | BT Help
Cheers
John
