Message 1 of 5
Parent control not working
Moving to a new house then all of sudden BT parental controls are not working - rebooting, adding website to blocking..... its nightmare especially with young kids in family!!! Need address asap pls.
Many thanks in advance
4 REPLIES 4
Message 2 of 5
Re: Parent control not working
Hi @phillipluy,
Thank you for posting and welcome to the Community. I'm sorry if the Parental Controls aren't working following your home move. If you haven't tried already, could you please try turning off Parental Controls and turning them back on?
  1. Log in to My BT with your BT ID
  2. Scroll down to the 'My Extras' section and click Personalise your settings in the 'Parental Controls' panel
  3. Slide the button to ‘Off’ in the BT Parental Controls section and your BT Parental Controls will be switched off
  1. To turn them back on slide the button to ‘On’. It’s that simple and any settings you have saved will be restored
  2. It may take up to 10 minutes for filters to be applied to an active browser session.
Please give that a go and let me know how you get on.
Thanks,
Paddy
Message 3 of 5
thanks.
No it does not work. Have tried many times: on/off, reboot... not work at all.
Message 4 of 5
Also there is NO 'My extra' section on logon page. it's under
Get more from My BT
then Your security to locate the parent control..
Message 5 of 5
Thanks for trying that @phillipluy
We'll need to take a closer look at this for you so check your inbox for my message and drop me a reply with your details.
Cheers
David
