Message 1 of 8
Parental controls not working
Hello,
Since moving to my new address in July, my parental controls have not worked. I click on to add them to my account and it gives me a pop up message to say wait 2 hours but nothing happens,???? I be tried it many times but nothing. I have factory reset my bt router however still not working, any ideas will be greatly appreciated.
Thank you
7 REPLIES 7
Message 2 of 8
Re: Parental controls not working
Hi @Hithere1231
Welcome and thanks for your post!
I am sorry for the problems you're having with Parental Controls.  We are very busy at present so to get this resolved as quickly as possible; give our guides in the helpdesk a call on 0330 1234 150.
Feel free to post back and let me know how you get on chatting with them 🙂
Thanks,
Robbie
Message 3 of 8
Hello,
My problem still hasn't been solved 😞. I've spoken to many of your colleagues. The BT-ID has been deleted and reset, however I still can't access the parental controls. I press activate and it come up with the green box and it does not progress any further. Help......
Message 4 of 8
Hi @Hithere1231, sorry that this is taking longer than you'd hoped to get fixed. Has the technical team agreed a call back to update you on the case or has it been closed?
Cheers
John
Message 5 of 8
Tuesday I should get a callback, however I was hoping anyone else could weigh in as my problem has them stumped.
Message 6 of 8
Hi @Hithere1231, thanks for getting back to me. This would not be something we can help with but we refer off to a specialist team. I've sent you over a PM so you can get in touch with the Mod team and we'll be happy to check the correct team are dealing with this for you.
Cheers
John
Message 7 of 8
mine does't work either - were you able to get your problem resolved?
Message 8 of 8
Nope, still waiting for them to get back to me .
