Message 1 of 6
norton password vault
Before BT linked up with Norton I was already a user of Norton Vault. Is it possible to transfer my existing log ins from Norton Vault to my newly installed BT Norton Vault.
5 REPLIES 5
Message 2 of 6
Re: norton password vault
Hi. I've also used Norton password for some years and left my original Norton Password account as it was. So BT antivirus is logged in with my BT login and Norton Password uses my Norton login.
Message 3 of 6
thankyou for your response. I used my old norton log in details when the bt norton vault had loaded but there are no log ins in the new vault. At the moment I am continuing with the old vault because I am afraid of losing the old log ins.
Message 4 of 6
I just carried on using the Norton Password Manager app on my Android phone and the Norton Password Manager plugin for the browsers on my Windows pc.
Message 5 of 6
Spoken to Norton I have now imported fron Norton to Norton. Because I have continued using other Norton products it had defaulted to the original norton. Now I am enabled. Thanks for your help though. Kind Regards.
Message 6 of 6
Good to hear that you're now sorted.
