Message 1 of 4
Xbox Code
I applied for the xbox pass and it’s all done.
It gave me the code but I never saved it. Can I find out what the code or do I just login with my Microsoft account it’s linked with
3 REPLIES 3
Message 2 of 4
Re: Xbox Code
Hi, @Dazza1 I'm glad your order has closed off this evening. The code can only be used once and is entered automatically when you linked it with your Microsoft account. You can check your subscription is active in your Microsoft account. It should now show you that it is being managed by BT, the duration will show 1 month but this gets renewed each month for the duration of the offer.
Neil
Message 3 of 4
Re: Xbox Code
Thx Neil
Message 4 of 4
Re: Xbox Code
@Dazza1 No problem, if you've any more questions just ask and we'll be happy to help.
Neil
