Message 1 of 31
Norton Password Manager - Vault is now empty!
I hated the change to Norton Password Manager.
I should not have switched.
Norton has lost all my logins and notes. My vault it totally empty.  Yes I am using the same account, signing in with my mybt account.
All data is lost. This is so unbelievably inconvenient! I use the notes to store AWS credentials and other vital data.
Do backup your Vault data while you can.
30 REPLIES 30
Message 2 of 31
Re: Norton Password Manager - Vault is now empty!
Same here.  Norton suddenly decides I have no subscription when logging in via my BT, and the browser extensions stopped working.  Now it wants be to create a new vault.  I can still access the old one vault via the iOS app - I'm trying not to get logged out of those otherwise that's hundreds of passwords gone.
Bring back Truekey, it was reliable unlike the integration between BT and Norton.
Message 3 of 31
Same thing happened to me today, complained to BT have been promised a call back to fix the problem.
Hopefully they will be able to restore my data will have to wait and see, not impressed with Norton at all.
Message 4 of 31
Logged in again just now and my vault has been restored everything seems to be back again hopefully everyone else is the same.
Message 5 of 31
Hi, @Steven3 I'm glad to see your vault is working again. @sandCanoe @richgorman are you still experiencing issues?
Neil
Message 6 of 31
Mine is also restored. Phew!
If you are the one that fixed it - thank you.
And clue to the cause?
regards
Message 7 of 31
Hi, @sandCanoe it was resolved by Norton this morning and I'm sorry for any inconvenience caused.
Neil
Message 8 of 31
Yes, sure enough mine is suddenly available again.  Relieved that it's back, but its a worry that they can just disappear.
Message 9 of 31
Hi @richgorman, thanks for checking and glad it's back for you also.
Cheers
John
Message 10 of 31
Norton Password Manager - Vault is now empty! AGAIN
BT and NORTON have to get this sorted.
My vault has gone again!
