Message 1 of 14
Bt tv remote not working at all, except to put box on and off
13 REPLIES 13
Message 2 of 14
Re: Bt tv remote not working at all, except to put box on and off
Hi @mikeinlyme and welcome to our community.
Sorry you're having problems with your remote. Have you tried changing the batteries? Which set top box do you have? What have to tried to resolve this?
Cheers
David
Message 3 of 14
Thanks for your reply David.
I have a Pro Box and have tried unplugging and then back on.
Tried reloading BT app.
Tried turning it all off from MY BT..
The remote will put app on and off and also mute the sound, so I assume that the battery is OK.
Any ideas?
Message 4 of 14
Thanks for the eply @mikeinlyme
How long have you had the pro box / remote?
Cheers
David
Message 5 of 14
18 months and it was working OK on Friday.
Message 6 of 14
Thanks @mikeinlyme
I think it's worth changing the batteries. If that doesn't help let me know.
Cheers
David
Message 7 of 14
Just the same. The box does nothing except mute and turn on /off
Message 8 of 14
Thanks for checking that @mikeinlyme
We'll need to get this looked into for you so I've dropped you a private message so you can get in touch.
Just a heads up, we're really busy right now so it's taking longer than usual to reply but once you send in the details we will get to you.
Cheers
David
Message 9 of 14
Please don't post personal details on a public forum @mikeinlyme . Just reply to my private message with the details.
Cheers
David
Message 10 of 14
Sorry. Couldn't find private message
