<p>From 31 October 2024, BT Cloud has <a href="https://www.bt.com/help/broadband/bt-cloud/getting-set-up/download-or-access-files/how-do-i-download-files--folders-and-devices-from-bt-cloud-">closed</a> and all data will soon be deleted.</p>
Re: There is no option to connect bt TV pro to wifi
I think you are just unfortunate in receiving a box that did not have the updated software. I had mine delivered in mid-December and the wireless option came up as part of the set-up.
