Message 11 of 15
Re: Error code 533
@Nick_P_Barrettwrote:
Received a call and have been advised that the spam algorithm has been adjusted to stop this happening again.
Error appears to have cleared, thank you.
I expect "they" altered the algorithm for just your account. I await the next report and will link in this answer.
Message 12 of 15
Re: Error code 533
Hello,
I have today hit the issue with this erro code. Can you advise why I can reply or forward emails?
I am using webmail and never had thess issues untill today. Have checked IP address and not black listed
Message 13 of 15
Re: Error code 533
@detaildevilwrote:
Hello,
Hi, welcome to the forums.
Its not any blacklist as such, though you will note that nearly all dynamic ISP IP addresses are blacklisted by default on many listing systems.
It's a system issue, that is seemingly unique to each person that reports this error. It is very common as a quick search for 553 in these forums will show. Despite that, the actual route cause doesn't look to be addressed.
I assume you meant "can't reply ..." rather than can in your post?
Your best bet is to get a Gmail address and use that.
Message 14 of 15
Re: Error code 533
Thanks Andy,
I actually deleted the images from the email that I was sent, then replied to the sender and it went through.
Very odd, as just this one email thats caused me issues!!!!
Message 15 of 15
Re: Error code 533
I did that but had trouble trying to import my contacts , they said BT was blocking it . Did you manage to do it OK
