Message 1 of 10
BT SMTP Server Fault
I suddenly found my emails composed on my phone weren't being sent. I tried removing and re adding my BT account from apple mail but no luck, it complained that the SMTP server password was wrong which was a complete red herring as I can login with the password to my webmail. On top of this if I disconnect my phone from my wifi and use 5G then the email sends.
I then searched this forum and found this is a very common problem and it is definitely down to issues with one or more BY SMTP servers. BT please get this fixed ASAP as it is a right royal PITA and I am paying for premium email service.
9 REPLIES 9
Message 2 of 10
Re: BT SMTP Server Fault
My wife and I have the same issue with our iphones. A right royal pain.
Message 3 of 10
Hi @MailOnly @wrlamb58
Thanks for coming to the community.
Which device are you both using?
Is your software up to date?
Just to make sure, could you check the settings are correct as shown in the BT Email server settings page.
Speak to you both soon 🙂
Leanne.
Message 4 of 10
All settings are absolutely correct. Ic they weren’t then the email wouldn’t send when I disconnect from WiFi and use 5G. This means that the only change is my iphone’s IP address, which in turn means it is definitely the SMTP server at fault. Please don’t ping pong this query just get your engineers to fix the issue please.
Message 5 of 10
Iphone 12 for both of us with upto date software. As suspected it turned out to be the outgoing server. Its disappointing that BT did not publicise the outage which resulted in wasted time trying to resolve the issue.
Message 6 of 10
The issue is still there. It maybe they fixed it on the sticky SMTP server that your IP addresses were associated with but if yours is fixed there must be yet at least one other SMTP server with the issues 😞
Message 7 of 10
It looks like the problem is with BT’s SMTP server, especially when you're on Wi-Fi. Since emails send fine on 5G, the issue is likely with BT's mail servers. You can try using other servers like SMTPmart, SMTP2GO, or SMTPget SMTP for better results.
Message 8 of 10
@Liorann
This post is over six months old so hopefully it has been resolved so you may not get a reply from the OP.
Message 9 of 10
This looks more like a BT SMTP routing or network-side issue rather than your password, especially since it works on 5G but fails on WiFi. When this happens, it’s usually something on the provider’s outgoing mail servers or connection handling that needs fixing from their end. If you need a stable workaround, you can switch to a third-party SMTP service like SMTPmart or Amazon SES, which generally work reliably across networks and avoid ISP-related SMTP issues.
Message 10 of 10
@brianlara
This post is now well over a year old so hopefully it has been resolved and as was pointed to the previous poster when it was six months old you may not get a reply from the OP.
