Message 1 of 7
email not sending
Hi !  It's a long time since I was able to send emails ... they never arrive. Suggestions would be appreciated. I can receive emails - no problem.
6 REPLIES 6
Message 2 of 7
Re: email not sending
If you are a BT Broadband customer has the BT Mail email account been used in the past 150 days?
Why has my email address been suspended or deleted? | Email | BT Help
or
Are you presently a BT Broadband customer or are you paying for your email through a BT Premium email account or did you migrate to EE Broadband?
If none of the above your email account may have been downgraded to a BTMail Basic account which can not be used with an email client or email apps.
See link
https://www.bt.com/help/email/bt-email-products
Message 3 of 7
Thanks but I've never had a BT Broadband Account. I've had the email account since before BT offered broadband. I receive emails without problem but if I try to send a message to multiple destinations the only one that arrives is that addressed to myself on a different webmail account.
Message 4 of 7
Who is your email account supplier?
Message 5 of 7
BT
Message 6 of 7
How do you have a BT email account if you have never had a BT Broadband account. What is your email domain?
When were you last able to send emails?
Message 7 of 7
Welcome to the Community, @stevereeve
Just to be sure with this, is it the dedicated BT Webmail portal that you're experiencing these issues in?
It's worth giving this a try in a different browser if that is the case.
Also you mentioned this seems to occur when sending to multiple addresses - does the same happen if you only select one recipient?
Speak soon,
Peter
