Message 11 of 17
Re: Call waiting
It does
Message 12 of 17
Re: Call waiting
So which button is it?
Message 13 of 17
Re: Call waiting
I don’t have a phone  like that but can see there aren’t buttons  labelled switch or reject , so I would imagine the screen display shows the call waiting options when a second call arrives, and as per the user guide you select the option you want..you obviously are in a better position to check , make two calls to your landline number and check the information screen
Message 14 of 17
Re: Call waiting
It isn't the advanced phone
Message 15 of 17
Re: Call waiting
Then the user guide for that isn’t going to be useful
Message 16 of 17
Re: Call waiting
Hello it's ok guys I have found out what happens thank you very much for your help!
Message 17 of 17
Re: Call waiting
It does indeed show on the screen when a second call comes in for the Essential phone.
